Rochester carburetors
Started by haineswrth, March 18, 2024, 07:44:07 PM
haineswrth
We have a 1955 Cad with the "superpower" engine.  It has two Rochester carbs.  We have not been able to find anyone here in Tampa who can work on them.  Any suggestions?
billyoung
Age 69, Living in Gods waiting room ( Florida ) Owned over 40 Old Cadillac's from 1955's to 1990 Brougham's. Currently own a 1968 Cadillac DeVille Convertible and a 1992 Cadillac 5.7 Brougham.
Clewisiii
I assume he means to tune a duel carb on engine. Working on any individual carb should be easy to find someone.
haineswrth
I am no expert but I am fairly confident that both carbs need tuning up at a minimum.  The car runs ok, but when running at any speed, if I step on the gas, it stumbles, coughs, and then catches.  Also, the mileage is abysmal, even for that type of car.
cadillacmike68
Quote from: Clewisiii on March 19, 2024, 09:55:56 AMI assume he means to tune a duel carb on engine. Working on any individual carb should be easy to find someone.
What are the two carbs fighting with each other?  :P
"Cadillac" Mike
Bryan J Moran
Do you have a CLC Roster? I assume also that you are in that local region. Someone in your region should have a referral.  Also, a technical advisor should be able to help.
CLC 35000 in number only
David King (kz78hy)
Since you are in FL, have Daytona Parts rebuild the carbs.  They supply most parts stores with carb kits and they do rebuilding as well.
https://daytonaparts.com/.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Good advice, but that is half the job, balancing them out on the engine is the other half of course.
David King (kz78hy)
Dave Shepard it right, but the 55 shop manual walks you through the adjusting sequence.  I've done it on mine it is very smooth at the moment.
David King
CLC 22014  (life)
1955 Eldorado #277
2012 Volt
haineswrth
I do have the shop manual and will review it.
As always, y'all are very helpful.  Many thanks.
Highwayman68
Where are you located in Florida?
