Gold Paint For 59/60 Tri Power Air Cleaner?
Started by 76eldo, February 25, 2013, 09:30:27 PM
Anyone know of a good match in spray cans or a formula for professional body shop use?
I have a nice Tri-Power air cleanerIi just acquired and would like to restore it and eventually sell it.
Have manifold and carbs too, plus a super rare oil bath Olds J2 Air cleaner.
Brian
Jeff Wilk
I tested the High Heat Gold Engine enamel on my 59 tri power air cleaner from Dupli Color that McVey's sells.  It is a very very very close match to what was on there and it covered beautifully.......
Jeff
Southern New Jersey
SOLD
1958 Cadillac Sixty-Special
1958 Cadillac Sedan
1958 Cadillac Coupe Deville
Is there a number on the can?  I'd like to try to find locally if possible.
Brian
Jeff Wilk
Brian, looks like McVeys took the UPC label off the can and put their own on instead that just says Eldorado Engine Gold!
It is a Dupli Color Engine Enamel Ceramic 500 Degrees
12oz cans with a Gold cap.
Jeff
Southern New Jersey
SOLD
1958 Cadillac Sedan
Jeff Wilk
Brian, i found it on the duplicolor website. Simply called "universal gold" in their Ceramic Engine Enamel line
HTH.........Jeff
Southern New Jersey
SOLD
1958 Cadillac Sedan
Gene Beaird
Not sure if you know it or not, but Cadillac painted the top of the air cleaner on the 68 Cadillacs gold to highlight the new-then 472 engine.  The closest color to the original for the 68 is called 'Drama Gold'.  I believe it's a Dodge color.  You may want to have a look at that color to see if it's a closer match.
Just a suggestion.  Not sure anyone would really care, unless you're working on a 10.   :D
Gene Beaird,
1968 Calais
1979 Seville
Pearland, Texas
CLC Member No. 29873
