39 Cadillac clock glass-"Found One"
Started by lou-q, May 06, 2015, 02:53:24 PM
lou-q
I'm still looking for the glass that is on the dash in front of the clock.
One from a LaSalle would also work.
Lou
Lou Quirch    CLC#26694
39-6127 coupe
67 DeVille convertible Venetian Blue
67 DeVille convertible Doeskin SOLD
67 Corvette Marina Blue Roadster
2015 Mustang GT 50th anniversary Black Convert
2020 Shelby GT500 Magnetic Metallic
67 DeVille convertible Donor car for parts
3 F250 Ford P/Us
lou-q
49er,
Thanks for the reply.
The glass with the numbers is OK. It's the curved glass in front of the one with the #'s that is broken.
Lou
39-6127 coupe
3 F250 Ford P/Us
ebuliavac
Are you certain there is a curve in this glass?  The reason I am asking is that I have a '40 Cadillac, no curve, but panel underneath and shine on glass gives appearance of a curve.  For my unit, a piece can be cut at any glass shop because the glass is flat.  I'm not sure how curved glass could fit in the housing, unless it is bent and has ears on it for mounting.  Perhaps yours is the same and you just need a piece of ordinary flat glass?  Ed Buliavac
1940 6227C
1996 Fleetwood Brougham
lou-q
Thanks Ed,
On the 39's the glass is definitely curved and so is the radio and speedo glass (the clock face with the numbers and the radio glass with the numbers are flat and go behind the curved ones). The glass is mounted between two formed pieces of sheet metal with tabs and two holes, then it fits in a chrome rectangular bezel that has two studs that go through the holes in the glass frame and fastens to the dash.
My clock glass was cracked when we bought the car. I cracked the radio glass when I took the dash out to refinish. I found a replacement glass for the radio area but no luck with clock glass yet. All three are different sizes.
Lou
39-6127 coupe
3 F250 Ford P/Us
las39
Yes the 39 has curved glass, one year only and very rare. My radio is cracked but clock and speedo ok. I was told they made them by slicing a big cylinder. Some one  should be able to that nowadays?.
Even thought about to have it done with pexi glass, but never got around it.
1939 LaSalle 5027
1941 Chrysler Royal Coupe
1934 Oldsmobile F34
1976 Moto Guzzi Convert
lou-q
Quote from: lou-q on May 06, 2015, 02:53:24 PM
Lou
Still looking!
Lou
39-6127 coupe
3 F250 Ford P/Us
Steve Passmore
I would go with a piece of Plexi-glass Lou. I don't think anyone would ever know. Its not like it would be rubbed often like a screen.
Steve
Present
1937 60 convertible coupe
1941 62 convertible coupe
1941 62 coupe
Previous
1936 70 Sport coupe
1937 85 series V12 sedan
1938 60 coupe
1938 50 coupe
1939 60S
1940 62 coupe
1941 62 convertible coupe x2
1941 61 coupe
1941 61 sedan x2
1941 62 sedan x2
1947 62 sedan
1959 62 coupe
lou-q
#7
Randall,
Yes, I still need it.
Can't seem to contact you by private e mail.
Lou
39-6127 coupe
3 F250 Ford P/Us
