1974 washer fluid low level indicator
Started by www.eldorado-seville.com, May 21, 2015, 06:46:02 PM
Hi,
the switch inside the float unit in the cap unit of my 74 Coupe deVille is inoperative - so whenever I turn on the wipers I get a "low washing fluid" warning. The FSM says that the magnet actuated switch inside the cap is not repairable.
I just cant find the float unit with the switch anywhere.
Attached you can see a picture of how the unit looks like. On the second picture I took, the magnet is installed incorrectly - it has to be on the other side of the spring...
Gerald Loidl
1958 Cadillac Eldorado Seville
1966 Cadillac Coupe deVille
1967 Cadillac DeVille
1967 Cadillac Fleetwood Eldorado
1974 Cadillac Coupe deVille
1978 Cadillac Eldorado Biarritz
http://www.eldorado-seville.com
http://www.cadillac-bigmeet.com
