1957 Cadillac Eldorado Biarritz windhose top ends
Started by raul.kolk, March 15, 2024, 08:25:58 AM
raul.kolk
Hello there!
I have a couple of questions regarding the wind hose. Should the hose's end be finished with a rubber cap or sewn?
Also, I have noticed a small bracket holding the top end screwed to the body under the quarter window panel. Could you please confirm if this is the correct installation method for my application?
Maez
My Seville (#250) had the rubber cap that had a metal tab attached. It was built in late 56. Does anyone make a reproduction rubber cap?
raul.kolk
#2
Quote from: Maez on March 15, 2024, 03:50:47 PMMy Seville (#250) had the rubber cap that had a metal tab attached. It was built in late 56. Does anyone make a reproduction rubber cap?
Yes, there are caps available on the market. We have them on our 57-6267X. However, the interior has been redone in the past, which makes it uncertain if the caps were originally used. Therefore, I am looking for clarification on this topic.
Windlace Rubber Stop - 1930-60's Oldsmobile, Cadillac, & Buick Holiday Coupe & Convertible
Maez
