Whats this?
Started by dogbergs, April 08, 2022, 08:03:59 AM
dogbergs
Found among the loose electrical parts for my -51.
Could it be a resistor in an early 12v conversion?
Mounted close to batteri. Can't find on any pics
or diagram.
/ Johan
-51 Cadillac serie 62 convertible, project
-64 Dodge Polara 2dHt, 1 driving and 1 for spares.
-70 Volvo 121 (Now sold after 21 years)
-63 Plymouth Max Wedge clone, project
-42 Harley WLA
-43 Royal Enfield WDCO
-33 Ford Pick up, project
fishnjim
There's some letter on the side that would give some clues that are not discernable from that view.   I have my guess, but can not say without all the info.
I suspect it's aftermarket.
dogbergs
#2
Quote from: fishnjim on April 08, 2022, 10:15:41 AM
SREC 00VD1 with something very blurry in between, and A B C D, one letter each ear.
Thanks / Johan
-42 Harley WLA
dogbergs
As you mentioned in pm, battery heater probably seems to be the answer, found holes in firewall behind battery tray that looks to fit, have not ever heard about such thing til now. Car has history in Anderson, Indiana, extremely cold there??
Thanks / Johan
-42 Harley WLA
dogbergs
Can't figure out purpose of these clips? By the dash fasteners.
-42 Harley WLA
59-in-pieces
Johan,
Are the threads in the hole good - or loose or shot.
JUST A WILD GUESS - What does the other side of the clip look like, removed from the dash.
If threads are bad and clip has either a tube with threads inside, or an open circle with 2 jagged spikes or a half circle with a cupped edge - lots of designs, but each is used to screw a bolt into and hold it in place without a nut.
Good luck,
Have fun,
Steve B.
S. Butcher
hornetball
Those are called "U-nuts."  Like 59 said, they provide threads.
dogbergs
#7
No, you see it all. No threads. Threads are in the body, underneath.
You can see the head of screw holding it.
Johan
-42 Harley WLA
That is definitely a new one on me.
Has anything been cut from the bottom of the piece?
dogbergs
No Bruce, looks stock and put back exactly as was.
Johan
-42 Harley WLA
dogbergs
-42 Harley WLA
Maybe it's just a spacer? From your last picture, I see a second one.
dogbergs
Yes, one for each dash fastener, but spacer that thin felt strange, probably is the case though.
/ Johan
-42 Harley WLA
dogbergs
Somebody help me understand? That the dip stick tube is broken I get. But the direction? Meant to be bent correctly?
-42 Harley WLA
You'll have to push it out from the inside. Its orientation is correct. The new tube will have to be inserted from the engine's exterior side.
dogbergs
Yes, absolutely but I realize now the pic is not that good. The tube goes straight towards the cap and dip stick cannot pass it without some bending.
-42 Harley WLA
dogbergs
Quote from: dogbergs on December 03, 2022, 04:11:54 AMYes, absolutely but I realize now the pic is not that good. The tube goes straight towards the cap and dip stick cannot pass it without some bending.
I quote myself, thats cool. Maybe thats just what it should do. The cap bends the dip stick right where it should be?
-42 Harley WLA
On my cars from the fifties, the dip stick usually strikes something before it's completely in. Don't worry about that!
dogbergs
Quote from: Roger Zimmermann on December 03, 2022, 04:48:06 AMOn my cars from the fifties, the dip stick usually strikes something before it's completely in. Don't worry about that!
As long its not a moving part Im fine with it!
Johan
-42 Harley WLA
Won't hurt to bend the new tube a little for better alignment.  That is exactly what you have to do with the 472/500/425 engines before you put the pan on.  There is a so-so picture of the proper tube alignment for those engines in my '73 shop manual.  Goes without saying, I guess, but just be sure the dipstick itself clears the rotating assembly when you are done and before the pan goes on.
