Oil pump gear clearance
Started by Roberts 63, January 18, 2022, 07:25:37 PM
Roberts 63
Hello All I have a 63 Cadillac with a 390 I'm putting new oil pump gears in it and would like to know what the clearance is from the gear to the case on the sides.
dadscad
Backlash between drive gears, .008" - .012"
Clearance between pump body and gears, worn limits, not over .005".
New limits, .003" - .005".
Clearance between pump body drive shaft, new limits, .0010"- .0025"
Worn limits, not over .005".
Enjoy The Ride,
David Thomas CLC #14765
1963 Coupe deVille
Roberts 63
Thank you Dave. That's exactly what I needed.
Quote from: dadscad on January 21, 2022, 05:26:39 PM
dadscad
You're welcome,  that's from the factory shop manual.
Enjoy The Ride,
1963 Coupe deVille
