1967 Eldo PARTS
Started by 60eldo, August 18, 2013, 10:50:12 AM
60eldo
   Let me know if you need anything from this car,,,its all there A/C Car has disc brakes, leather interior in nice shape
Jon. Kluczynski
waterzap
Does this car have the tilt steering column?
Leesburg, AL
waterzap
I would love the indicator switch. But I know most people only sell the whole column, which is a bit more than what I need.
Leesburg, AL
Coupe Deville
Randy Kimberly
#4
I need the original lower radiator hose.  Is yours of the original type?  If so I would like to buy it.  I also need the suspension compressor attached to the left tie bar.  Please let me know the cost.  randyk38@comcast.net
Matt CLC#18621
What is your email address?
thanks,
matt
CLC# 18621
60eldo
#6
    You can email me at jkcarrrremail addresses not permitted,,,I will be at the car Sunday let you guys know if I have these parts
Jon. Kluczynski
I may be interested in the hubcaps.  Don't have to be all 4, I will take what ever is there.  Don't have to be perfect as long as the price is right.
60eldo
     All 4 caps are there and an extra grill,,,I will contact you soon
Jon. Kluczynski
60eldo
#9
   Ok,,,I got to the car today, took more pics, I will try answer all you today,,,sorry for the delay
Jon. Kluczynski
Coupe Deville
waterzap
If you can, maybe put the car on the Classic Oldsmobile forum, or the Toronado Owners Group forum. I am sure there are parts that will fit the Toronados
Leesburg, AL
60eldo
  Waldo,,,doesnt have tilt,,,,so just the switch
Jon. Kluczynski
60eldo
      Heres on of the hub caps, I have 3 more
Jon. Kluczynski
60eldo
  Anthony, Ill send you some pics of the headlight pistons on thurs, and carb
Jon. Kluczynski
Hi,
I'm interested in the a/c and heater parts. It is understood that they may not work, but they can be used as cores.  Parts I'm interested in are:
Compressor and mounting brackets,
fiberglass heater box and power servo
Fiberglass a/c evaporator casing (with evaporator, POA and expansion valves)
hoses
dash control unit
transducer under glove box
What part of the Country are you in?  I'm in VA 22039.
Scot
60eldo
       OK Scot , please call me the A/C is complete
Jon. Kluczynski
60eldo
   Randy, you should have your part by Friday,,,thanks
Jon. Kluczynski
60eldo
   Waldo, are you still interested in the signal switch?
Jon. Kluczynski
waterzap
Leesburg, AL
