1941 Master Cylinder
Started by afeltham, November 16, 2011, 05:30:34 PM
afeltham
Under category "1941 Brakes sticking" .....in 2005 Bill Sullivan wrote" bleed hole must be open. I am having a similar locking brake problem - .
Question: Two holes can be seen when viewing into the reservoir through the fill hole...one is about 1/4", the other looks about 1/8...should BOTH be clear straight through from the reservoir to the piston bore? What size is the smaller bleed hole?
Alan Feltham CLC Member#11926
Jeff Maltby 4194
Yes. You need to pay close attention to Bills post above and adjust the rod P with the nut U and Clevis V as per shop manual.
Jeffo 49er chapter
CLC 1985
Honda Gold Wing GL1500
