Horn relay location on a '69 coupe deville
Started by Mihai Tarţa, April 12, 2013, 06:47:24 AM
Mihai Tarţa
I bought my car with the rim-blow busted, and the previous owner installed a horn button on the lower part of the dash.
I bought a '75 steering wheel horn pad and I want to do a conversion for the horn. I know that most people convert to a '70 horn pad, but I think that the design of the '75 horn pad looks much better and fits much better with the design of the '69 than the '70 horn pad.
The horn wire (white) is still in the steering column, but I need to know where it's supposed to be connected at the other end.
I think that the (loose) end should be somewhere on or around the horn relay.
Thanks!
1969 Coupe DeVille
1976 Eldorado Convertible
Oradea, Romania
