1940 Lasalle generator
Started by tturley, March 21, 2016, 01:57:31 PM
tturley
The book says generator has 2 oil cups. One on back is easy but can't find the other one.
Any help appreciated
Member # 28929
1940 Lasalle model 5019
2011 Escalade platinum Edition
1995 Ford F-150
2015 Buick Enclave
Jeff Hansen
Tom,
The other would be on the top front of the generator directly above the front bushing.  If your generator does not have this oil cup, the generator was likely changed at some point and has a sealed bearing instead of a bushing.
Jeff
edited by Jeff: correction.
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
tturley
Thanks for the reply.
There is not one on the front so I guess it was changed. Do the lateroneshave a modern bearing in front but not in back ? That seem strange.
Member # 28929
1995 Ford F-150
2015 Buick Enclave
dplotkin
When these are rebuilt typically permanently lubed bearings are used. Maybe someone decided to replace only one bearing.
Dan
60 Buick Electra six window
60 Chrysler 300 F Coupe
62 Pontiac Bonneville Vista
63 Chevy Impala convertable
63 Ford Galaxie XL fastback
65 Corvette convertable 396
68 Chrysler New Yorker
Jim Stamper
     Or maybe both are replaced, no way to get rid of the oil cup or reason to, it looks " correct " with it still there.
     I have done that on brass cars and others. If it takes oil it likely hasn't been replaced with a new bearing.
                  Jim Stamper CLC# 13470
tturley
Thank you all for your comments.
Member # 28929
1995 Ford F-150
2015 Buick Enclave
If it has been removed you should see a tiny hole on the front flange. It could have been snapped off.
tturley
My generator has something that looks like an air scoop attached to the top of it covering where I think the oil cup would be.
Anybody know anything about that?
Member # 28929
1995 Ford F-150
2015 Buick Enclave
