Power Vent windows
Started by SK903, May 26, 2017, 11:56:32 PM
SK903
In what year did power vent windows first become available?
2012 BMW 535I
1961 Eldorado Biarritz
David Greenburg
First appeared on the '57 Eldo Brougham, and were available on the rest of the line in '58 (standard on Eldorados and the Fleetwood 60S).
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
SK903
I somehow remember seeing roll down windows on the 58 Eldos. Am I wrong?
2012 BMW 535I
Eric DeVirgilis CLC# 8621
Quote from: SK903 on November 26, 2017, 12:42:58 PM
Highly unlikely.
william_b_noble
FWIW, my 59 has power vent windows.  the gears had gotten damaged and I was able to find replacements (modern reproductions I think).  that was years ago.
Bill N - clc # 2371
59-in-pieces
Bill,
I have had the same problems.
They originally had a nylon gear that directly connected to the shaft of the motor and axle, that either broke at the connection/axle, or the gear stripped.
The replacements were made of steel (see pic).
Have fun,
Steve B.
S. Butcher
I once saw a 61 Coupe DeVille with hand crank windows.  The car was at a Government surplus sale.
D.Smith
#7
Quote from: Glen on November 27, 2017, 12:58:49 AM
Cranks vents? or crank windows?     In 1961 the base model Series Sixty Two coupes and Sedans had crank windows.
Power windows were standard in the Fleetwoods, deVilles, Eldorado Biarritz and Series Sixty Two convertibles.
Power vents were standard in the Fleetwood Sixty Special & Eldorado Biarritz.
Power vents were optional on all others if equipped with power windows.
The car you saw must have been a Series Sixty Two coupe.
Below:
Sedan deVille
Sixty Special
Matt CLC#18621
Baffles me when someone took the time to sit in a Cadillac dealership and order a fully loaded Cadillac during the 50's, 60's and maybe the 70's and made a concision decision not to order Power Vent windows if they were optional.
When the beautiful 1967 Fleetwood Eldorado was introduced, Cadillac made the mistake of making "manually operated rear vent windows standard on this luxurious behemoth, opting instead to designate Power Rear Vent Windows as optional for an additional $63.15.
During 2015, I looked at a fully loaded, family owned 67 Fleetwood Eldorado that was built during May, 1967, in Tampa. The original owner having taken the time to equip his 1967 Fleetwood Eldorado with bucket seats, tilt, cruise, Twilight Sentinel, Guide-Matic and power front disk brakes but did not order the optional power rear vents as he deemed them unnecessary. I was confident that if I were to purchase this 67 Eldorado, I could swap out the manual vent windows with power vents, but in the end, I am a purest and I prefer an unmolested vehicle built on the assembly line. Notwithstanding the aforementioned, the Estate was asking for what I deemed to be an exceptionally high and unreasonable premium for its beautiful 67 Fleetwood Eldorado.
Still looking for a 67 Fleetwood Eldorado with a sunroof installed by American Sunroof Corporation. I believe there is a Venetian Blue across the pond, owned by Gerald Loidl.
Have a great week!
Matt CLC#18621
Bob Hoffmann CLC#96
Matt,
What were the miles on that car & how much was the price?? What color was it in & out?
Thanks, Bob
Quote from: D.Smith on November 27, 2017, 07:43:04 AM
Below:
Sedan deVille
Sixty Special
It is possible it was a series 62, but it had crank windows, and crank vents.
