carter afb carb
Started by 60kaddydaddy, September 23, 2017, 07:39:38 AM
60kaddydaddy
1960 won't idle on cold starts.Runs ok when engine warms up but I have to stay on gas to warm up engine.
Is it time for e rebuild?
Does the choke work?    What often kills the chokes on stuff this age is the choke heater tube/stove rots out in the intake and lets exhaust into the choke which then damages and plugs it up.
There's a procedure to follow to set the choke first.   Fast idle is on a cam and if you don't engage, it won't.   You do not want to flutter the gas starting up.
Refer to owners or shop manual or AFB service bulletin.
