Instrument Clusters differences
Started by stevecleland@ymail.com, November 14, 2017, 04:17:01 PM
I was wondering if anybody knows if you can substitute certain instrument clusters for others.  I need an instrument cluster for a 1988 El Dorado.  Maybe one from another year will work fine...I don't know.  Maybe somebody can assist me with this issue.  Thanks a lot.
Is yours digital?    Standard issue USA or you need a metric one?
Eric DeVirgilis CLC# 8621
All Eldo/Seville instrument cluster is digital 1986-1991. Can't comment on model year compatibility.
#3
This may work. Seller says for diesel but not the case as there was no diesel engine after 1985 and this style cluster is for Seville/Eldorado beginning 1986.
"Premium Fuel Only" stated on gauge beginning 1990 so this cluster is 1986-1989.
https://www.ebay.com/itm/86-87-Cadillac-Seville-Eldo-Digital-Dash-Speedometer-Diesel-Fuel-Gauge-Odometer/322858246177?fits=Year%3A1989%7CModel%3AEldorado&epid=3007877803&hash=item4b2bd9e021:g:8F4AAOSwFSxZ8EeV&vxp=mtr
Quote from: TJ Hopland on November 14, 2017, 06:58:10 PM
it is digital, standard issue usa
Dan LeBlanc
If you go to www.car-part.com you can do a junkyard search for your part.  It will automatically search all interchange parts based on the options you enter.
Give it a shot.
Dan LeBlanc
