Window Motor
Started by jaxops, March 27, 2011, 10:22:02 AM
jaxops
I bought a replacement window motor from USA PArts for my 56 Series 75 LR door.  The hardware did not come with it, and it was one size smaller than the original motor hardware.  The only thing that fit was a Phillips head screw with a 1/2 inch shank.  Has anyone gone down this road before?  I had the original motor reconditioned once and it gave up the ghost on me.  I am worried that the torque will either break the screws on the new motor or they just won't hold.  They don't seem to tighten up properly.
Any thoughts on this would be appreciated.
1979 Lincoln Continental
Bob Hoffmann CLC#96
Mark, Welcome to the wonderful? world of inaccurate reproductions. I'd suggest drilling & retapping the holes to the correct size.
HTH, Bob
The motors on the 1956 are round, later around 1959 they are flat rectangle -- but they still fit. So you might consider using a later motor. Unless the 75 was different from the 62 series?
the johnny
I can send a picture of the 56 and the newer one if you need one.
John Washburn
CLC #1067
1937 LaSalle Coupe
1949 62 Series 4 Door
1949 60 Special Fleetwood
1953 Coupe DeVille
1956 Coupe DeVille
TonyZappone #2624
John, would you send a picture?  I would like to compare it to the one I posted a few days ago.
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2016 Cadillac CT6 Platinum
Tony,
Sent the pictures to you e-mail address.
The Johnny
John Washburn
CLC #1067
1937 LaSalle Coupe
1953 Coupe DeVille
1956 Coupe DeVille
jaxops
Thank you for the replies.  Turns out USA PArts sent me a motor with Metric threaded holes.  I called and they just sent a new one.  Now to get that regulator back in there!!!!  The hard part is how does the regulator connect on the hinge side of the door?  I think it just stands up like an "I" and it bolts top and bottom, and then the slide and rollers bolt on the handle side of the door.  Do I have that right?
jaxops
 >:( Yup.  The new window motor from USA Parts Supply only goes one way, and only for a second and then stops.  It is clearly not electrically compatible for this car.  I put the old window motor back on and it goes down fast, but I watched the motor's plastic gear spinning when it tried going up.  I am resolved to repair the old motor and put it back on.  If I had a 1978 Cadillac, this window motor would purr right along.
  I did figure out how to get the regulator back on the window slide, so it was a good "exercise."  :'(
