Frontbumper alignment
Started by Oldcaddy 56, August 10, 2011, 01:26:45 PM
Oldcaddy 56
Hello,
For some time I own a Cadillac 1956 Coupe de Ville and have started restoration but I want to keep the car on the road.
I noticed the frontbumper out of line, the right side sits higher. To readjust it do I have to take the whole bumper of or just loosen bolts?
It is not crash damaged.
Greetings,
E. Oosterhuis
Keep it moving, old man!
Pretty basic, get under the bumper and look at the attaching points, you as you say can, loosen the bolts and get some up and down movement you may need an assistant.
Oldcaddy 56
Hello Dave,
Thank you for the reply, I will get at it soon.
Kind regards,
Erik
