GM Heritage Center: Anybody Home?
Started by Eric DeVirgilis CLC# 8621, May 03, 2015, 05:20:48 PM
What is wrong with this picture?
Quentin Hall
You are right Eric. That engine needs to be donated to me to put in my 39 custom. It's what Harley Earl would have wanted.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Besides that, Q.   ::)
Hint: Look at the display tag.  ;)
54 caddy larry
Larry M
1954 series 62 coupe
1974 Harley Davidson FLH
My caddy is my never ending work in progress.
Quentin Hall
Well they definitely need to give it to me now. The V12 engine is probably out the back being used to chock the back door open. I'll buy a new shiny door chock and take that clunky old green incorrect engine off their hands.
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
57 Biarritz
936CD69
If you look closely, you can see the fan of the V12 engine displayed to the right of the V16.....
Craig Brillhart CLC# 26217
1993 Sedan deVille Spring Edition Carmine Red White Top-SOLD!
1993 Sedan deVille Spring Edition Triple Black
CLCMRC Benefactor #302
Quote from: 936CD69 on May 03, 2015, 06:43:00 PM
You're correct Craig.
I had to resize the image to see that. My screen cut most of the fan out - all I could see was a vertical white bar.
936CD69
It helps that I have had the privilege of seeing the display in person...
