Marvel Mystery Oil in cylinders 1939 Cadillac Series 61?
Started by dennisspeaks, December 21, 2023, 11:47:09 PM
dennisspeaks
Tomorrow is the big day I am going to put on my PI hat for the 39 Series 61 Caddy.  It's been sitting in a barn since 1990.  Typically on all cars that have been sitting I remove the spark plugs to put the mystery oil in, however I am told you can't do it that way with these flatheads.
Looking for some insight on what will be involved to do this and suggestions.
Thanks in advance!
Merry Christmas
CURRENT CLASSIC CARS
1939 Cadillac
1976 Eldorado convertible
1978 Toronado XS
1994 Deville
1989 Fleetwood
1989 Town Car
1982 Mark VI
PAST CARS
1978 Biarritz
1978 Eldorado
1978 Biarritz
1978 Biarritz
1974 Eldorado - RIP
1976 Eldorado Vert
1975 Sedan d'Elegance
1990 Sedan Deville -gave to son
1988 Fleetwood Brougham - gave to daughter
1968 GTO
1965 Olds 442
1975 Caprice Classic Sold
James Landi
Happy Holidays Dennis--
Not certain why Marvel Oil won't help a decade's old slumbering engine, especially a flathead.  Flooding the cylinders with Marvel oil would provide stuck piston rings and rusted valves stems stuck in the block with lubricant, as well as provide the cam with lube. Main thing to remember, don't attempt to use the starter until you're able to rotate the engine by hand ''Armstrong'' approach...    There are several You-Tube video personalities that feature ''waking up'' such engines... the better of them are both entertaining and informative...Vice Grip Garage videos is one such offering. Also, search You Tube for guys working on long slumbering flatheads... it's highly educational.  Keep us posted Dennis... channeling success and happiness in your direction.   James
z3skybolt
James,
That is exactly how I "woke up" my  1937 Buick straight 8 engine that had not run in over 30 years.  Took a few days and gentle pressure being applied before it finally freed up.
Bob R.
I think one thing that gets people with flatheads is the spark plug tends to be more over the valves than the piston so when people squirt oil in it ends up staying in the valve area if the valves are closed or in a manifold if they are open.  I think V engines tend to have the valves at the top so this isn't as much of an issue in this case but could be a reason 'they' say its not the same since 'they' more likely have an inline engine that the head is horizontal on.
dennisspeaks
Happy Holidays James,
The big question of course is how to do it.  Yes I have watched a few of the videos on waking up cars, just none on flatheads. I believe I have found someone local that has one and works on his
Thanks for your well wishes, may all of your days be blessed.  Happy Holidays.
Quote from: James Landi on December 22, 2023, 08:46:19 AMHappy Holidays Dennis--
1939 Cadillac
1978 Toronado XS
1994 Deville
1989 Fleetwood
1989 Town Car
1982 Mark VI
PAST CARS
1978 Biarritz
1978 Eldorado
1978 Biarritz
1978 Biarritz
1974 Eldorado - RIP
1976 Eldorado Vert
1968 GTO
1965 Olds 442
dennisspeaks
TJ, hopefully the local guy that has a flathead another friend was telling me about will be will be willing to give me a hand or at least some guidance.  I will follow up with my friend after the holidays and take it from there.
Thanks for your input.
Happy HolidayA
Quote from: TJ Hopland on December 22, 2023, 05:41:05 PMI think one thing that gets people with flatheads is the spark plug tends to be more over the valves than the piston so when people squirt oil in it ends up staying in the valve area if the valves are closed or in a manifold if they are open.  I think V engines tend to have the valves at the top so this isn't as much of an issue in this case but could be a reason 'they' say its not the same since 'they' more likely have an inline engine that the head is horizontal on.
1939 Cadillac
1978 Toronado XS
1994 Deville
1989 Fleetwood
1989 Town Car
1982 Mark VI
PAST CARS
1978 Biarritz
1978 Eldorado
1978 Biarritz
1978 Biarritz
1974 Eldorado - RIP
1976 Eldorado Vert
1968 GTO
1965 Olds 442
