'62 bad Cruise motors
Started by arch62, May 05, 2022, 11:51:50 PM
arch62
Looking for old '62 Cruise control motors that don't work, have bad or burned windings etc.
Have possible solutions, but need a few to experiment on. Instead of scraping will take a few to try.
Gary W Thorne
Hi Peter, I have a couple that only turn in one direction & I also have at least one '59-60 that needs help.  If you can resurrect the '62 motors, then you should be able to fix the '59-60 motors. I believe they are all the same basically except they're inside different outer casings.
  I'd be happy to give you the '62 motors for fixing the '59-60 motor(s).
What do you think?  There will be shipping costs depending upon how many are shipped...weight/etc. which needs to be negotiated.
Cheers,
Gary
