"??Y Pipe??"
Started by Ronw010711, August 15, 2022, 07:32:38 PM
Ronw010711
I'm looking for what is sometimes called (incorrectly) a "Y pipe" or "connector pipe" (again incorrect). It is a brass pipe that goes from one side of the manifold to the other. The pipe is only about 5/8" - 3/4" O.D. It was the same item used on '71 thru '75, 500 ci engines. In the Cadillac parts manual it is identified as "Manifold to Cylinder Head Air Infection" part #1602996. It also needs 2 each, "Asbestos Seals" part #1490752.
This part is NOT associated with the exhaust system (again another incorrect assumption).
Thanks for your help.
Ron
Ron
I sent you a PM
