Speedo gear seal
Started by oregonjam, March 30, 2024, 04:45:33 PM
oregonjam
Should there be a seal on the speedometer driven gear shaft sleeve to the tail housing?
I disassembled and there was no seal there. Should there be one or was thread sealant used?
John
Cheers,
John Miller
1960 Series 62 Coupe
1954 Oldsmobile Rocket 88
1968 Camaro SS
1968 C10 SWB Pickup
1976 Bronco Sport
No seal, or sealant on the thread.
The speedo driven gear shaft should have a spiral wound groove in the outer circumference to "wind" the excess transmission oil back down the shaft.
This is sufficient for oil retention within the transmission.   Any oil leaking out will mean that the transmission is too full.
My experience with a TH400, is the plug supporting
the speedo driven gear has an outer O ring to the
case, and an inner seal to the plastic gear, both
replaceable.  The problem is the plastic wears and
may no longer make good contact with the inner seal.
Bruce Roe
