59-60 Engine Bolt ID Help
Started by 60eldo, February 23, 2024, 05:48:14 PM
60eldo
  Can anyone tell me what these bolts go into. I think the 60 engine but Im not sure. Especally the 5.5 inch one on the right with a point on the end.
Jon. Kluczynski
David King (kz78hy)
maybe the valley pan cover, there is long special one that connects the draft tube & valley pan cover at the rear.
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
60eldo
Dave I think that one is thinner, but ur right the bolt ur talking about also has a pointy end and is long, mine has the width of a head bolt
Jon. Kluczynski
59-in-pieces
Jon,
I agree with David, as they are the only bolts that I recall that have pointed ends to help them start to thread, when you are blind once they go through the valley pan to mount it to the engine.
I posted a couple of pics to help identify where the shorter ones go and the longer in the back (draft tube - correct title), don't forget the washers, one each.
Hope they help.
Have fun,
Steve B.
S. Butcher
60eldo
#4
  Valley pan bolt on the bottom, big difference. I know Ive seen this bolt on the top some where before, but cant place it. It will not fit into the heads, so its larger in diameter.  Larger than a head bolt.
Jon. Kluczynski
David King (kz78hy)
The shorter one resembles a head bolt.  Now that I'm looking at the longer one again, I think it goes to something else.  The long one appears to be a 12 point and I can't remember any spot a 12 point is used.
David King
CLC 22014  (life)
1955 Eldorado #277
2012 Volt
60eldo
#6
 Dave skinny one is valley pan bolt.
Jon. Kluczynski
