1937 LaSalle Body Mount Rubber
Started by carlhungness, March 21, 2022, 07:11:57 PM
carlhungness
    I bought the Steele body mount rubber pads that have an indexing hole and they have to go on top of the frame.
     Then I also have the Steele rubber grommets listed for body so assume they go under the frame. The original's were of a thick webbing material and I believe there was a thick webbing washer under the frame. The indexing hole should sure make it easier to drop the body on in place.
Am I correct? Should be mounting the body in a few weeks.
The Steele prices have gone up over 20% in the last few weeks.
