1960 Coupe - Metal around rear window
Started by TrevorK, January 25, 2017, 08:10:00 PM
TrevorK
Hi,
The metal around the left side of my rear window is rusted out. If someone had a parts car that has this section I'm wondering if it would be easier to patch with a section from a car, rather than fabricating something. Anyone have a 1960 coupe with this section?
Trevor
Trevor Korsrud
1960 Cadillac Coupe DeVille
1963 Cadillac Convertible
Not sure if one piece from another vehicle would be able to be inserted successfully, but with deft cutting and fitting, anything is possible.
The best thing I would be suggesting is to replace individual sections, and then each part can be fitted perfectly as a jigsaw puzzle, then buttoned up.
Just because you can see rust, there will be parts underneath, and out of sight that will be just as bad.
Chuck Patton
Hello Trevor
Glad to read you are improving your 1960 Cadillac.
Joe Karasinski and Brian Rachlin are performing restoration's on their 1960 Cadillac's at this moment.  Both gentlemen are extremely knowledgeable and honest.
Appraiser-Broker-Consultant
Past CLC National Board Director
Past CLCMRC Director
Past CLC Motor City Region President
CLC 1959-60 Cadillac Chapter Director
CLC Life Member #23147
