1976 instrument cluster lights
Started by Jcquicker, October 05, 2023, 02:23:01 PM
Jcquicker
I need to replace some bulbs in my instrument cluster. Can the cluster be removed without removing the dash pad? Any advice appreciated!
V63
Yes the cluster can be removed as you thought. You might consider LED bulbs as they seem to offer much better visibility.
