Steering column swap
Started by Denise 20352, August 13, 2005, 07:10:33 PM
Denise 20352
  Well, swapping an early 70s tilt/tele column into the 76 hearse went perfectly.  It was an easy bolt-in and plugin fit.  It sure does make getting in and out of the car easier.  I was also pleased to see that my hydraboost pan drain hose modification fits neatly around the column.  Maybe Ill take a picture after I get the new boost unit in.
-densie
