for sale 331 engine parts
Started by piperman, May 06, 2012, 08:56:00 AM
piperman
Have a completed engine with fly wheel. I'm parting out. Would sell engine needs rebuild
D John Anderson
Jay Friedman
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
piperman
D John Anderson
Chasmann
LOOKING FOR HEAT RISER VALVE.ALSO POSSIBLY DISTRIBUTOR THANKS CHARLIE MURRAY CONTACT 516 987 3354
1949 SERIES62 4DR SEDAN                                      1936 SERIES 60 4DR TOURING SEDAN
rghobden
The year of manufacture will be the first two digits of the engine's serial number as in 51 62 00087, which is stamped on the engine block casting under the generator.  In this example, the year was 1951, the model it went in was a series 62 and it was the 87th engine made that year.  There were slight differences in the life of the 331 from year to year so it could be important to buyers of some of the parts.  Russ Hobden, #1235
Russ Hobden, CLC #1235
Jay Friedman
The engine serial number is stamped on a boss at the upper right front of the block.  If the right (passenger's side) cylinder head is still on the block, the number is just in front of the cylinder head at the point where it joins the block.  If the right (passenger's side) cylinder head is no longer on the block, the number is on the top of the block just in front of the number 1 (forward most) cylinder.
Decatur, Georgia
piperman
D John Anderson
