Carl 61 Fleetwood Phyllis
Clewisiii
I could not find a set of ground straps for the upper AArms. So I decided to make a set.  Less then $30 and I have enough to make 50.
Now I just need to find an appropriate screw for the attachment to the AArm
6262
1962 Cadillac Series 62
1965 Pontiac Bonneville
Clewisiii
Quote from: 6262 on June 06, 2023, 12:29:55 AM@Clewisiii  Where did you get this set?
I bought the material on Amazon and crimped my own.
Cadman-iac
  In the interest of continuity, you may want to solder your terminals in addition to the crimp just to be sure you have a good connection.
 I solder every terminal myself to ensure there are no problems.
 I realize that these are just ground straps, but the solder would help keep the strap from pulling out of your terminals if there were any stress on them for some reason.
 Rick
CLC# 32373
Clewisiii
My front springs are ready to reinstall.  But man I hate it. These seem to compress by half just for install.
I may wait until the engine and trans is in place just so that the front springs have some type of weight on them while sitting.
Cadman-iac
  Yeah, the problem with no weight on your suspension is that the bumper stops are squashed, unless you leave them out until after there's enough weight on the frame so you can install them without any pressure on them then.
 Your frame looks great though.
Rick
CLC# 32373
G'day Carl,
The best method is to cut some pieces of hardwood to the desired height, and simply put them in place of the coil springs.   Complete the car build, and when there is sufficient mass on the front end, then use the vehicles weight to aid in fitting the actual springs.
Clewisiii
It is a little nerve racking cutting the holes for the radiator overflow clips.  Every little slip drilling the corner holes was scary. But I think I did fine. I don't think that I actually touched the inner tubes and they seem to be as tough as this outer plate which took a bit to actually drill through.
Clewisiii
I ordered my exhaust from Waldron's today. I got stainless steel. I also ordered the heat riser spacer from Caddy Daddy with a few other odds and ends.
My distributor is boxed up in my car. Waiting for me to drop off at the post office.
Waiting to hear about my trans cooler lines. They should be done this week or early next week
So I am excited. Feeling motivated.
Clewisiii
Light dusting on the core. I will get a couple of coats on the tanks.
I ordered the overflow clips. I ordered the radiator hoses. And I have a set of NOS hose clamps.
I still hope to set the motor next week.
But I don't believe I will start it till October.
Clewisiii
What are your thoughts on radiator caps and originality.
I think the authenticity manual says they are gloss black. I have my original but I assume the temp spring is probably inaccurate now.
Would you just pick one up at the parts store.  Or is there a more appropriate option.
Clewisiii
Heat Riser Spacer. $100
There is a steel shop and a laser cutter around the corner from me. I should try to make some money.
Clewisiii
#532
Well I managed to get this ball joint for $140. Still expensive
Clewisiii
Looking at my parts car, and the bracket on the rh manifold.  I remember the bolt on the front. But I do not remember the rear
The parts car was already apart and a few things switched out.   What goes to the rear of this bracket on a 61 with AC.
David King (kz78hy)
The bracket on the exhaust manifold looks to be the generator bracket
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
David Greenburg
Definitely looks like a generator bracket.
David Greenburg
'60 Eldorado Seville
'61 Fleetwood Sixty Special
Clewisiii
Quote from: David Greenburg on June 19, 2023, 01:44:40 AMDefinitely looks like a generator bracket.
Yes I remember using the front side of this bracket
But I cannot remember how the back engaged. I will find out in a couple of weeks
Clewisiii
Very surprising what a quick trip through an acid bath can do to clean up these brackets.  Anyone else a a surprising acid trip?
Clewisiii
Tedious. Beyond tedious.  Jason does not have all the restored fasteners I will need for my 61. And some parts are too big for my small plating set up. So this batch is going to a yellow zinc plater to be barrel plated.
Bead blasting out every thread. I have worn through the gloves in my blasting cabinet.
Clewisiii
Thank you @StevenTuck for guinea pigging the Corvette door conduits. My set showed up today.
