1957 Original Cadillac series 62 Vee length
Started by Bill Balkie 24172, December 31, 2017, 08:57:35 AM
Bill Balkie 24172
Hello ,
    I am looking for the over all length from point to point  of the original 1957 Cadillac series 62 ( not  Brougham ) front hood vee . I have two after market  Vee’s one measures 15 7/8 and the other 17 1/2 . Both are marked 1957 Cadillac hood on the back . Just purchased one from McVeys and that is the one that is  17 1/2 .   Both hole patterns match . Thank you for your time .
   Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
cadparts58
Bill,
1957 point to point 17 3/8 inches 58 16 5/8 inches  I have three or four 57's two were 17 3/8 and one was 17 1/2.  May have been bent at one time to make the difference in length. I also have a 56 that is 16 inches, but only has three mounting pins. I didn't measure width of VEE or distance of mounting pins. Hope this helps. Frank
Frank Puma #10721
Bill Balkie 24172
#2
Frank ,
     Thank you very much , not sure where the other Vee came from , however it does fit the hole pattern on the 57 Cadillac hood . And it is marked on the inside 57 Cadillac hood . However it is just 16 inches from point to point . Looking forward to installing the new McVey Vee . It is beautiful.
Thanks again for varifying the correct measurement of 17 1/2  inches .
     Bill
Bill Balkie
1970 Coupe DeVille
2009 CTS
