This ignition switch was on my 1941 Cadillac.
It was restored in 2021 and works great. It was dis-assembled, cleaned thoroughly and a new wire installed into the body of the switch. It comes with a new GM Key and a chrome bezel that screws over the end of the switch. The chrome on the bezel is rough, but could be re-chromed.
The wire (to the coil) is a least 26 inches long. The part number on the body of the switch is 1116298.
I believe this could be used for other year and model Cadillacs. The switch does not have the accessory function. It also does not have the armored cable and coil cap.
Message me if interested.
Thank you
