(4) 1941-1946 16" rim(Series 67 & 75) full disc wheel covers with blemishes $350
Started by Scott Anderson CLC#26068, July 20, 2020, 01:03:49 AM
This is a set that have been rechromed and never mounted on wheels. They do not have the center emblems. The chrome is well done - they have a deep uniform luster. However three of them have some small blemishes from the chroming process apparently.
One is just fine.
Three of them have some small blemishes from the chroming process apparently. One has one small pinhole and a small 'smudge' or 'smear', one has about 3/8" dimple, one a little bit of dust or some such in the chrome in one area.
They are excellent driver quality, and realistically could also be used for show due to the chrome quality as the defects are very hard to find unless they're marked out. I'm having trouble with photos for some reason here. Email me at sanderson1962email addresses not permitted and I can send that way.
To be clear (thank you Jim Govani) please note that they will not fit the smaller 14" wheel cover / 15" rim cars (Series 60S, 61, 62, 63). They will only fit the larger cars (Series 67 & 75), 15" wheel cover / 16" rim cars.
1941 Cadillac 6267X Convertible Coupe
2014 Cadillac CTS-V Coupe
Jim Govoni CLC 20546
Please note that they will not fit the smaller 14" wheel cars (Series 60S, 61, 62, 63).  All those models have 15 inch rims. Section VI (W) of the authenticity manual. 67 and 75 have 16 inch wheels, I think that's what you mean.
1953 Series 62
1966 Fleetwood
1969 deVille Convert.
1941 Series 63
Jim,
Thank you the nudge. I was deliberately trying to be brief to avoid the rim vs cover size confusion that can happen; I reread the post with that in mind which made it apparent to me that my brevity had accomplished the opposite.
Change made in both title and body.
TonyZappone #2624
These are very scarce items.  Second only to the 16" steel sombereos for the 47-49 75s.  35 years ago I found a set of the 41-46, and put them on my 49 75, cause nothing was available!
Tony Zappone, #2624
1936 Pierce-Arrow conv sed
1947 Cadillac Conv cpe
1958 Cadillac conv
2016 Cadillac CT6 Platinum
