1976 1977 1978 Cadillac Alarm Controller 9349676 GM #192169968502
Started by 76Collector, August 10, 2021, 09:11:14 PM
76Collector
1976 1977 1978 Cadillac Alarm Controller 9349676 GM #192169968502  Fleetwood Eldorado DeVille Seville Limousine Factory original part number 9349676 alarm box module controller also includes miscellaneous wiring lock cylinders door alarms sensor switches under hood alarm switch there are no keys to the lock cylinders however they can easily be made for under $20 at most locksmith key shops.  Great move from low low mileage 1976 Eldorado with factory installed alarm system. Email: markjones858@yahoo.com
