1956 Bendix brake master cylinder booster to Moraine?
Started by smilasm, March 06, 2020, 11:22:00 AM
smilasm
Hi,
i have a question. If it's Bendix brake master cylinder, booster in my 56 SDN DeVille now, can I change it to Moraine set, is it direct fit? Thank you in advance.
Marius Smilas
1956 Sedan DeVille  http://bit.ly/1hsWhri
cadman56
I believe you will find they will interchange ok.
1967 Cadillac Eldorado (sold)
Larry Blanchard CLC #5820
Cadman-iac
 If you're referring to the complete unit, booster and master cylinder,  yes, they interchange.
  The difference between them is the Bendix unit has 3 bolts attaching the master cylinder to the booster, and the Moraine unit has 4 bolts.
The  master cylinders can't be swapped by themselves.
CLC# 32373
smilasm
Marius Smilas
