1957 gas tank
Started by 13814, October 14, 2017, 10:10:14 AM
13814
1957 Coupe, I have installed a new tank & 5/16 steel  feed line.  The connection at the tank will not tighten or seat the flair. The shop manual  calls for a gas line spacer. All attempts  so far to buy  the proper fitting have come up empty handed ! Is there a source or  alternative  available ? THANKS
vegas49er
Hi, There is a spacer in there that is tapered on both ends. It is also there if you have a tank with a return line although for 1/4 inch. You can make a spacer also. The companies that sell new tanks include a spacer and they may sell you one. I have a couple of fuzzy photo's I took back when I was working on a few 57's so will try to include them now. F.J.
13814
Thanks. About what I expected  it to look like. I called most of the cady vendors from Hemmings, no one seems to know where to get one. Any help locating one would be appreciated !
C Gorgas
I have installed and removed my tank a number of times for various reasons and found the inserts at NAPA where they have a bin of many different fittings. Might try them. Chet 25441
13814
I located the fuel line spacer from Auto City Classics Thanks
