1941 Convertible Coupe / Rear window frame size? /
Started by manfredrusche, January 23, 2023, 10:59:42 AM
manfredrusche
Who can tell me the correct original size of the rear window frame (length and height) for the 1941 two-door convertible? Thank you, Manfred
Jeff Hansen
Manfred,
I can't tell you the dimensions of the window frame, but I can give you the dimensions of the window glass if that would help you:  according to the CLC Authenticity Manual for 1941 Cadillacs, the glass is 9 inches in height by 28 inches in length.
Jeff
Jeff Hansen
1941 6019S Sixty Special
1942 7533 Imperial Sedan
houseboats1
I can measure the frame for you just take me a day or two
