Trim Removal
Started by Craig Lewis CLC#21155, February 19, 2006, 08:12:35 PM
Has anyone got a method or special tool ar any idea on how to remove the mouter trim pieces (beltline trim and window trim)? I have a 1947 6107. The clips are screwed in and I can see them from the inside after removal of the headliner. But they are not just snapping off as I try to pry it on the outside. I dont want to distort or ding the trim. there is a lot of corrosion on the clips. Also is there a place to get replacement clips?
Craig
