Need 1949 door latch or restoration
Started by boulton, April 04, 2016, 07:33:30 PM
boulton
Hello,
I Have a 1949 model 62 Sedanette that my grandmother bought in 1957.
The drivers door key lock has never worked.
I have the drivers door latch out and found the typical issue with the pot metal tab broken off.
I am looking for a good used latch or somebody that can restore/replace the tab on mine.
Thank you!!
Eric Boulton
503-709-7182
Jay Friedman
Try www.allcads.com.  They have a part to fix the latch.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
johnwalker
Unfortunately, the repair part is for convertible or CDV only.
1949 6207
1950 6137
1940 6019S 3 window coupe
1948 olds 98 sedanette
1947 diamond t pickup
1930 model a roadster/392 hemi
1949 cadillac woodie (was a buick)
1933 chrysler royal 8 3 window coupe
1977 930
1987 911 cab widebody
1969 911E
boulton
Tab "C" is the pot metal piece that breaks.
Somebody must be replacing/restoring this part on the latch.
49caddyman
Eric:  If You still need this door latch assembly, please contact me directly at:  49caddymanemail addresses not permitted     I'm quite certain that I have a good used one.  Joe Cutler
