Bulk correct vacuum lines
Started by raugusti, May 23, 2014, 10:34:41 AM
raugusti
Hey all,
Looking at the 58s, all of them are going to need the vacuum lines replaced (as well as other cars I'm working on).  I was just about to buy several rolls of different size spools of Gates vacuum tubing on Amazon when I wondered if there is a source for the correct vacuum lines with the 'ribs' or 'draw lines' as original?  If the vendors sell it, somebody makes it, but has anyone found a retail source for this in bulk?
Scott
Scott Augustine
Colorado, USA
'58 Series 62 Conv.
'58 Eldorado Seville
C.R. Patton II
Hello Scott
Try contacting Craig Wood at McVeys.
David King (kz78hy)
Mastermind has the correct 4 tube extrusion.   It also comes with a routing diagram.
57EB12-023 is his item number.  Go down the page about a third of the way.
http://www.mastermindinc.net/rubber-parts1.html
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
raugusti
Thanks David, I'll give him a call!
I had looked at that molded 4 line piece and figured there was no way anyone re-popped that.
That is what is forum like this.   :)
Scott
Scott Augustine
Colorado, USA
'58 Series 62 Conv.
