Removing Fine Scratches From Windshield.
Started by Ralph B., November 05, 2006, 07:08:25 AM
Ralph B.
Has anyone ever successfully removed fine scratches from windshield glass, such as those made by the wiper blades ?
I would appreciate hearing from anyone that has accomplished this, either by doing it themselves, or having had it professionally done.
Rhino 21150
Whitney sells a glass polishing kit with very fine abasives suited for the job. They also sell it at some auto parts stores and body shop supply houses. I did it years ago by hand; get the no swirl polisher from Black and Decker. Results depend on your fine steady hands, or the guy at the glass or body shop. No worse than polishing a paint job.
Chris Bryant #19358
You could also use toothpaste or corn starch in the same way. Paste first then the corn starch to finish off.
Chris
Rhino 21150
