1956 Eldorado Seville - Ribbed floor mats ?
Started by Zwildman1, October 04, 2020, 06:25:19 PM
Zwildman1
I am looking for a source for the ribbed floor metal pieces that attach to the carpet under each seat including the rear seats as pictured.  The picture is off the internet as an example.  Any ideas on a source to help me finish my restoration?  Thank you for your assistance.
Mike Josephic CLC #3877
I assume that you refer to the ribbed aluminum
floor pieces that are on the driver and passenger
side -- two in the front and two in the rear.
They also have rubber inserts between each rib.
They were used in the Eldorado vs. standard floor
mats.
If you need the aluminum mats themselves, to my
knowledge nobody is reproducing them. You will
have to obtain those from a parts car.  These are the
same for 1955 and 1956.
If you are fortunate to find a usable set, the rubber
inserts (black only) are reproduced by FEN Enterprises.
http://fenenterprises.com/index.html
Good luck,
1955 Cadillac Eldorado
1973 Cadillac Eldorado
1995 Cadillac Seville
2004 Escalade
2011 Buick Lucerne CX
CLCMRC Museum Benefactor #38
Zwildman1
Yes, that is what I am referring to.  Thanks for the insight on a portion of the material.
denniscaddy
I have one (of 4).  It is not the driver's, which is different.
Very hard to source these.
dennis@caddyparts.com
Dennis
CLC 3676
1941 Fleetwood 60S
2017 CT6
brian faull clc#25881
I might have a set. I will look through my stuff this week. Thanks, Brian.
Bigfins (Dan Morehouse CLC 16464)
I have several sets... and 55's and 56's are different for the drivers side front.  I've only had 55's that were black, but I have had several different colors from 56's.
Yes, there were multiple colors available for 1956
for the rubber inserts including, black, red, blue and
green.  However, I am not aware of anybody
reproducing those.  So it may be a mate of black or
nothing.
2004 Escalade
I looked through my parts, I have a set of 4 with black ribs. The fronts are the same size, so I believe they are for 1954. If you are interested, let me know.
I will try to post some pictures later. Thanks, Brian. 412 952 6027. cadillac32v@hotmail.com
Here are a couple pictures of the set of 4 that I have. Thanks, Brian. 412 952 6027. cadillac32v@hotmail.com
