1940 60S rocker trim
Started by pauldridge, September 12, 2011, 07:11:50 PM
pauldridge
My 60 special has no trim on the rocker panel under the doors.  (1940)  I've seen pics of other cars that had a wide trim strip on the rocker panel.  Has my car been short changed, or were there different options for 1940?
Phil Auldridge
Austin, TX
1940 60S as well as MGA, Stingray, '39 Ford Coupe, BMW 3.0 CS, '59 Jaguar, '51 Hudson Hornet, '64 and '70 Mercedes roadsters, and Nash-Healey LeMans Coupe
[img]http://www.auldridge.org/images/hdricon.jpg[/img]
Terry Wenger
Phil:
Your car had three stainless strips on each side. They are each 3/8 to 1/2 inch wide and ran the full length of the rocker panel. All the '38, '39 and '40  60S cars had these strips.
Terry Wenger
Terry Wenger CLC #1800
tewv16@sbcglobal.net
1932 355B TSD
1939 7557
1940 60S
1941 60S
1947 6267 Conv.
1949 6207X Coupe
1963 60S
pauldridge
Terry,
Thanks.  I guess I'll have to start looking!
Phil
Phil Auldridge
Austin, TX
Fred Pennington 25635
Unless it originally had running boards,  If it is just the molding missing you will have holes for the clips to hold them.
If it was a running board car with the boards missing then you will need the rocker extension to mount the molding or find a set of running boards and hardware
Good Luck
Fred P
Fred Pennington, CLC 25635
1940, LaSalle 5019
1940 LaSalle 5019 parts car
1968 Ford Bronco
1973 Mustang Convertible
2012 Shelby GT500
Don Boshara #594
Running boards were not an option on the 60 Special. The 39 & 40 LaSalle & 39 Cadillac 61 strips are too short. Good luck.
1940 Sixty Special
1966 Mustang Cpe
