Restoring My 67's Gauge Cluster
Started by Evan Wojtkiewicz, December 23, 2015, 11:57:34 PM
Evan Wojtkiewicz
#20
Painting the dash bezel was easily the most redundant part of the whole project. I had to fix several mistakes and wound up redoing it. The first lesson that I can relay from my mistakes is to be very careful in taping it off. I messed up the little stripe that runs along the bottom of the bezel which in turn led to some careless mistakes that wound up ruining the first paint job. The close up pic below is the correct paint area. I found that 3M Automotive Performance Masking Tape worked best.
The second mistake I made was choosing the wrong paint. Initially, I chose Dupli-Color flat black the first time I painted it. It looked beautiful and seemed sturdy. The problem was that the can stipulates a seven day curing time. The second time I painted it was a few days before I was going to put it back in the car and I chose Krylon flat black. The Krylon looked good, but chipped off in a few places where I handled it when reinstalling it in the dashboard. Doing it all over again, I'd definitely go with the Dupli-Color.
For prepping the surface I started by using a chemical paint stripper to get the old paint off. Sanding down the pits in the chrome turned out to be enough to smooth them out. I'd recommend Dupli-Color's Adhesion Promoter before spraying on the primer. A few coats of primer was more than enough to perfectly smooth out the remaining surface imperfections when sanded with 400 grit paper in between coats.
I tried to paint it outdoors at first, but the pollen and other debris floating around in the spring air made that impossible. Although I'm not endorsing this, I wound up painting it in my basement. I got a cheap box fan and duct taped a furnace filter to the back and constructed a crude spray booth out of cardboard. I opened up as many windows upstairs as I could and wore a face mask.
CLC 29623
1967 DeVille convertible
www.eldorado-seville.com
Great job! Thanks for posting your progress - very interesting read!
Gerald Loidl
1958 Cadillac Eldorado Seville
1966 Cadillac Coupe deVille
1967 Cadillac DeVille
1967 Cadillac Fleetwood Eldorado
1974 Cadillac Coupe deVille
1978 Cadillac Eldorado Biarritz
http://www.eldorado-seville.com
http://www.cadillac-bigmeet.com
DeVille68
nice job!
I hope you put your original rosewood back in the panel!
Evan Wojtkiewicz
Thanks! Actually, the 67's had a brushed aluminum trim insert. I understand that some 68's (with cloth seats?) also had aluminum dash trim.
CLC 29623
DeVille68
Quote from: Evan Wojtkiewicz on June 08, 2016, 02:42:48 PM
ah, oh yeah. That is correct. For 68 it depends on the trim level of the car.
Evan Wojtkiewicz
Although I finished the project over a year ago, I've only now gotten around to posting photos of the completed cluster. If anyone decides to tackle this project and has questions, feel free to send me an email.
CLC 29623
D.Smith
Jason Edge
Quote from: Evan Wojtkiewicz on January 24, 2016, 09:09:36 PM
As you may have read in my rant post about the ’67 interiors (http://forums.cadillaclasalleclub.org/index.php?topic=139471.0), I have been unsuccessful in finding a local plater willing to take on my dash bezel. So far, I’ve been to four or five shops. They either don’t plate pot metal, or they do but they don't use the appropriate process (street chrome), or they do plate pot metal with the correct process but they can’t do mine because it’s too complicated.
I have had excellent results with pot metal chrome plating thru Atlantic Coast Plating - http://www.atlanticcoastplatinginc.com/.  They are expensive (like all decent chrome shops) but do great work and have pretty quick turnaround time. I haven't sent them a dash instrument cluster bezel (yet), but they have done my arm rest switch panels and many other misc. interior and exterior parts and have been very happy with their work. If/when I do a dash instrument cluster bezel, it will be with ACP!
Jason Edge
Lifetime Member
Exec Vice President
CLC MRC Benefactor
2002 Escalade EXT - Black
67_Eldo
Great job!
I'm embarking upon restoring the instrument cluster (not the whole bezel) in my 67 Eldorado so this is very helpful.
My face plates have only small spots of corrosion so I'm trying to find a way to touch up the semi-gloss black on the speedometer face as well as the rectangular, silver frames around the left-side idiot lights.
I also need to clean some rust out of the main cluster housing and repaint the blue regions.
The worst area on my car is the shift-position indicator which I might strip and start over. It is small enough to, I don't think, be a tremendous time sink.
When you replaced the bulbs, did you use LED bulbs or stick with the original incandescents?
I didn't realize that OGPI sold the Mylar printed circuit for the dash connections. The one from my Eldorado looks exactly like the one they depict for the non-Eldorados so I sent them a query to see if their part will also fit an Eldorado. We'll see.
Thanks!
