Vacuum Hose Routing 1957 V-8??
Started by Dan Koser, August 12, 2011, 09:43:22 PM
Dan Koser
Reassembly proceeding apace. My question is about vacuum hose routing: I've connected the vacuum wiper motor to the vacuum pump output co-located with the oil pump. I've connected the vacuum output from the front of the carb to the distributor vacuum advance. BUT....there is a vacuum output at the top of the intake manifold in front of the carb - what is this supposed to be connected to? Any help would be appreciated.  Thanks,    Dan :o
Walter Youshock
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Dan Koser
Walter.....that is EXACTLY what I was looking for! Thanks so much for the link to that earlier discussion. So, the first thing I have to do is obtain one of those vacuum manifolds, as my car doesn't have one. But at least when I get one, I'll know what to do with it. Thanks again! Dan
Walter Youshock
You're very welcome!
If you haven't had the motor rebuilt, nothing you do will make the wipers work--which they hardly do anyway.
That manifold was used at least from 1956-1958.  I'm not sure about '55.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
