Sun visor and windshield wiper question 57 De Ville
Started by Renato, December 16, 2011, 11:05:47 AM
Renato
My sun visor slowly falling down. I put a plastic to the shaft, but I do not know the English name of this part. Maybe sy has a photo from it?
Second thing. Wipers are waggling. I realized a missing parts too. It's between the wipers and the wipers arm (where can diable them). I thing it  must be sg which hold it together. I need this part English name too :) Thank you!
R. Bognar
Quentin Hall
53 Eldo #319
53 Eldo #412.
53 Eldo #433
57 Biarritz
53 series 62 conv
39 Sixty Special Custom
57 Biarritz
Renato
Hello,
Thanks, but I got these parts. I need which hold the wipers on the wipers arm. I think sg missing from there.
R. Bognar
Renato
Just to see clearly. I made a blue circle the affected area. So thats's point my wipers are shaking. They are not fix. Do they need the plastik shoes which I linked above?
R. Bognar
Renato
R. Bognar
David King (kz78hy)
#6
The plastic cam faces are located at the base of the wiper arm, so they are not your issue.  I believe there are 2 sizes of wiper blade holders and if yours is loose on the arm, then you might have the wrong size of blade/holder.  The blade assembly should snap on to the wiper arm and fix pretty tight.
David
David King
CLC 22014  (life)
1958 Eldorado Brougham 615
1998 Deville d'Elegance
1955 Eldorado #277
1964 Studebaker Commander
2012 Volt
CLCMRC benefactor 197
Renato
How can I fix it? Where can I find a good part. Arm holds the wiper blade, but not strong.
R. Bognar
