'76 a/c compressor rebuild?
Started by Hankk17, July 05, 2012, 08:04:57 PM
Hankk17
does anyone know if there are rebuild kits available for the '76 A/C compressor?  my SDV's A/C was working until I messed with it like a fool.. it was and still is grinding like it's going to seize up, so I decided to give it a shot of oil.  Since then the compressor won't disengage and its now blowing hot air instead of the nice icy air it was before.
I thought perhaps I overfilled it so I've done a few quick purges by hitting the shrader valve and letting the coolant out for about 30 seconds at a time but the problem is still there.
Either way, the grinding is still there so I'm thinking a rebuild is in order..
Wherever you go... There you are
Hankk17
R Schroeder
No problem. I typed  " A6 compressor  " in Google. There may be more places.
Hankk17
FYI I corresponded a bit with one of their sales guys and he tells me that if a compressor is seized, they won't work on it.. presumably it'll cost more to rebuild than it would to buy a new one.
so, I did some searching and found one on Amazon of all places.. for $154.00.  I'm expecting it sometime next week.
I've also heard from several sources that the A6s are now a discontinued item - so get em while there's still stock I guess.
-Hank
R Schroeder
It probably will be shipped without oil, so make sure you have the correct amount.
Roy
Rob Troxel
I too picked one up off Amazon for my 68 Cadillac, rebuilt 4 Seasons unit.  Works great.  Cost was under 200 bucks  shipped, so I'd shelved the rebuilding of the old one.
I have also used Classic Air listed above for many other parts.  Top notch help from real people who know A/C there.
