1960 Autronic Eye Wiring
Started by Scott Halver, November 02, 2014, 07:01:05 PM
Scott Halver
Does anyone know or remember how the autronic eye is wired ?   I have a lead from under the dash that connects to the "eye" and probably plugs into the "box" but then I'm not sure.   The autronic eye "box" has been missing off the car for a long time.   I bought an autronic eye box from a salvage yard.............with 2 separate leads off the box......   not sure how it wires into the system.    The headlights have been working with the dimmer switch dimming the bright lights.   Thanks,  SHalver #24920   1960 Cadillac
1960 Eldorado Seville, Grandfather Bought New
1970 Corvette Convertible 350/350
Walter Youshock
1960 is Guidematic.  It has the "safety salute" feature where all 4 lamps flash for a second and then dim.  There has to be a separate wire to both high and low beam.  Check the shop manual.
It's really neat to see it work properly.   It does get the attention of the oncoming driver who neglects to dim his lights.
CLC #11959 (Life)
1957 Coupe deVille
1991 Brougham
Scott Halver
Really, I did not know that it would give the on-coming driver a "courtesy" flash.   I have the shop manual but I've never read about the courtesy flash.   I appreciate the info.   The shop manual doesn't always answer all of the questions.........  like looking at the wiring diagram, it provides colors of wires but you might not know that three of the four wire come together in one plug and the other wire is in a separate plug.  Thanks for responding,  SHalver #24920
Eric DeVirgilis CLC# 8621
The "salute" system dims all four headlamps first, followed by the inner two headlights turning off a second later.
