1940 turn signal switch
Started by 49 Sedanette, December 06, 2016, 07:54:51 PM
49 Sedanette
Hi all:
I am looking for the turn signal switch for my 1940 series 62 coupe.... the one that is a very short chrome lever sort of fixed at the end of an extension of the steering column.... probably not a clear explanation but I am sure that if you know a 1940 Cadillac, you know what I am talking about.
In case somebody has the switch all together with the chrome lever, please let me know:
vmilke at nutryplus dot com
Thanks!
V.Milke
V.Milke
Barry M Wheeler #2189
Recently, (a few months ago), there was discussion on the Forum about 1940 turn signal levers. The discussion ended, I believe, with the thinking that this once plentiful item's supply has dried up. I would suggest that you join the CLC mainly to obtain one of our Club Directories. The reasoning behind this is that in the book, each member that owns a 1940 Cadillac or LaSalle is listed. Many of these members do not use this Forum, so that they will not know/see of your need. Many also do not use the Web.
Therefore, what I always suggest is that you fill your cup with coffee and start dialing your phone. Most of our members will accept cold calls to talk about their cars. Usually during the conversation, either that person will ask if you have a "so and so part", or you can also ask about needing your turn signal lever.
Please note the time zone you are calling to, and try not to call at meal time or bedtime. Best of luck in your quest. BW.
Barry M. Wheeler #2189
1981 Cadillac Seville
1991 Cadillac Seville
49 Sedanette
Thank you Barry. I appreciate the suggestion.
But if somebody has one that could sell, I am still open to purchasing it.
Thanks!
V.Milke
V.Milke
johnwalker
1949 6207
1950 6137
1940 6019S 3 window coupe
1948 olds 98 sedanette
1947 diamond t pickup
1930 model a roadster/392 hemi
1949 cadillac woodie (was a buick)
1933 chrysler royal 8 3 window coupe
1977 930
1987 911 cab widebody
1969 911E
Do you believe that's the correct one for 1940 John? as there's another similar listed. They may all fit somehow I guess but these sellers just list a wide spectrum of cars they may fit.   I haven't got my 1940 anymore to confirm it.
http://www.ebay.com/itm/1940s-Auto-Lamp-8000-8906-Car-Truck-Turn-Signal-Switch-Dodge-Ford-Chevy-VINTAGE/151435671167?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D38530%26meid%3D2e6d17de8851405180143d1dac54aa85%26pid%3D100005%26rk%3D3%26rkt%3D3%26sd%3D232189001522
Brad Ipsen CLC #737
This is not the normal 1940 switch.
Brad Ipsen
1940 Cadillac 60S
1938 Cadillac 9039
1940 Cadillac 6267
1940 LaSalle 5227
1949 Cadillac 6237X
1940 Cadillac 60S Limo
johnwalker
Oops, I should have compared it to mine before posting. Looked pretty close.
1949 6207
1950 6137
1977 930
1969 911E
