rewiring 1939 Lasalle tail lights
Started by HFDJR1959, June 25, 2017, 10:27:26 PM
HFDJR1959
Any advice how to take apart the bulb assembly and rewire.  I believe I have a short within the bulb housing.  Seems like either the parking light or the brake light wire insulation has disintegrated  around the little springs that give tension to hold the bulb in place.  If the springs rub against the bulb housing then there would be a short.  The housing seems to be pressed in place, so I don't want to mess it up.
Thanks,  HD
CLC Member 30062
1939 LaSalle 2 door coupe
Past Cars
1965 Deville Convertible
1970 Eldorado
1934 Buick
1937 Plymouth
1950 Mercury 2 door
1966 Pontiac LeMans Convertible
1968 Corvette Convertible
1970 Ford F100
1972 Chevelle Convertible
Repaired dozens of these. If it's not the wire fraying then the small Bakelite bases may be broken.  These bases with their wire are available. 'Bobs' sell them for the twin or single connectors.
http://bobsautomobilia.com/electrical/page-4/?features_hash=1-1-187-USD
HFDJR1959
CLC Member 30062
Past Cars
1970 Eldorado
1934 Buick
1937 Plymouth
1950 Mercury 2 door
1970 Ford F100
Jay Friedman
Another vendor that sells parts to restore / rewire tail lights etc. is Restoration Supply, Escondido CA.  www.restorationstuff.com
I've redone several lights of all kinds using their stuff.
1949 Cadillac 6107 Club Coupe
Decatur, Georgia
CLC # 3210, since 1984
