346 water in the oil and cylinders??
Started by gary griffin, August 09, 2017, 06:45:04 PM
0 Members and 4 Guests are viewing this topic.
gary griffin
Finally getting ready to start my engine and am getting water in the oil and cylinders??   Gained about an inch in the oil pan also.  ????  Possibly not enough torque in the head bolts and gasket leak??
Gary Griffin
Bobby B
Gary,
Like This?  >:(
                Bobby
1968 Mustang Convertible
1973 Mustang Convertible
1969 Jaguar E-Type Roadster
1971 Datsun 240Z
1979 H-D FLH
Jeff Rosansky CLC #28373
Has it run at all? That sounds like a lot of water transfer for an unpressurized leak?
Jeff
Jeff Rosansky
CLC #28373
1970 Coupe DeVille (Big Red)
1955 Series 62 (Baby Blue)
Dad's new 1979 Coupe DeVille
gary griffin
Current best guess is head gaskets. I used new copper ones with copper sealer on them but they may have sat too long and the sealer irregularities are causing leaking?
Gary Griffin
autoluke
Only a head gasket if you are lucky.
My recent experience with the same issue led to finding  a crack in the block.
Could have been repaired via the stitching method, but  I decided to have all component parts moved to another unit.
Phil
Phil Lukens
