Cleaning the windshield washer glass bottle
Started by Justin Norwood, February 10, 2018, 09:00:33 AM
Justin Norwood
Does anyone have any recommendations for a chemical or process to clean the glass bottle that holds the windshield wiper fluid on a '47 Caddy? Mine is a hazy blue color due to the solution that has been in it for 70 years. I've tried soap and scrubbing with a wire brush...and it helped, but it isn't going to get the job done.
Thanks in advance!
-Justin
1947 Cadillac Series 62 Sedan
Caddyholic
1962 Coupe Deville
harry s
You could also try glass polish from Griot:
https://www.griotsgarage.com/product/fine+glass+polish+16+ounces.do?from=ac&cx=0
I would not use a wire brush but you could try bronze wool (fine) which is softer than steel wool and does not scratch. Good Luck,      Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
gkhashem
How about some bleach, then rinse it out good
1970 GMC C1500
1992 Oldsmobile 98 (OCA 1st)
1996 Oldsmobile 98
Past Cadillacs
1959 Coupe Deville
1966 Coupe Deville (Sr #861)*
tripwire
I've had some luck using Bon Ami kitchen cleaner to clean glass.
Driving now:
2023 XT4 Luxury
1940 LaSalle 5229 C4D
A few I used to drive:
1976 Cadillac Ambulance
1969 Cadillac Hearse, Superior Body
1966 Buick Wildcat Hearse
1957 Ford Thunderbird x 3, 1 E code, 2 D code
1956 Oldsmobile Rocket 88 Sedan
1949 Mercury Convertible
1949 Mercury Coupe, Mild Custom
1936 Buick Special Sedan
harry s
...also Heloise says you can mix a little water with Arm & Hammer baking soda to form a paste and coat the area to be cleaned and let sit for a period of time and rinse. Repeat as necessary. Good Luck,    Harry
Harry Scott 4195
1941 6733
1948 6267X
2011 DTS Platinum
Justin Norwood
Thanks everyone! I am trying these one-by-one until I find the best approach. I will reply back once I have the results.
-Justin
russ austin
R.Austin
